Go Back   6th Gen Accord DIY and Performance Forums > The Garage > Accord Tech
Accord Tech Anything tech-related that doesn't necessarily fit in the other forums. CEL Codes, torque specs, etc all go in here
Register to remove these ads
Reply
  #1
Old 08-09-2018, 03:26 PM
cumsies's Avatar
cumsies cumsies is offline
Junior Member
Points: 1,555, Level: 11 Points: 1,555, Level: 11 Points: 1,555, Level: 11
cumsies is an unknown quantity at this point
Angry Adding oil to the ENGINE fixed my tranny?! NANI?!
back in Feb of 2018, my automatic transmission started slipping like heck and I took it to a shop and it was stated that I needed a rebuilt transmission. asked several professionally trained mechanics and they all said the same. during the time that the transmission started failing, the engine was fine on oil. so I was also sure that the transmission needed replacing.
lacking the funds to do so, we just had it sitting in the lot for the last few months. so I thought it was obvious that the oil levels would lower.
and this guy, a family friend, shows up and says "bro you stupid you just need oil." and I got super pissed because I was so sure that just adding oil to the ENGINE would not fix my transmission.
I humored him. let him do whatever. he put in oil. started the car. and I was ready to be disappointed.
he comes back to the place and tells me its working and now the tranny will actually shift again.
WHY? WHY DID HIM PUTTING OIL INTO THE ENGINE MAKE MY TRANSMISSION ACTUALLY SHIFT? ANSWERS PLEASE
__________________
~ 🔰 cumsies 🔰 ~
  #2
Old 08-09-2018, 03:31 PM
cumsies's Avatar
Junior Member
Exclamation does a tranny fail on low ENGINE oil levels?
my accord's been sitting for the past few months because of tranny failure, automatic, and this guy comes over today and all he does is add oil to the engine and suddenly my car will actually shift again.
....why?
__________________
~ 🔰 cumsies 🔰 ~
  #3
Old 08-09-2018, 03:51 PM
DarkSideAccord's Avatar
DarkSideAccord DarkSideAccord is online now
nadeshiko fobz ftw..
Points: 131,691, Level: 100 Points: 131,691, Level: 100 Points: 131,691, Level: 100
Activity: 99% Activity: 99% Activity: 99%
DarkSideAccord should be someone you can trustDarkSideAccord should be someone you can trustDarkSideAccord should be someone you can trust
Re: Adding oil to the ENGINE fixed my tranny?! NANI?!
vtek oil yo~~~
sounds ike your car was in limp mode aka not enough motor oil... motor will only shift up to a certain rpm, so it makes sense that your tranny won't shift into higher gear
__________________
Originally Posted by Sketch o5 View Post
roy could live in Monaco, have won multimillion lotteries 7 times and hit $500k profit at a casino once a month, and he'll still be living in a ghetto and broke as fuck.
  #4
Old 08-09-2018, 04:02 PM
Sketch o5's Avatar
Sketch o5 Sketch o5 is offline
purp og
Points: 124,219, Level: 100 Points: 124,219, Level: 100 Points: 124,219, Level: 100
Sketch o5 is a name known to allSketch o5 is a name known to allSketch o5 is a name known to allSketch o5 is a name known to allSketch o5 is a name known to allSketch o5 is a name known to allSketch o5 is a name known to all
Member Photo Albums
Re: does a tranny fail on low ENGINE oil levels?
engine oil is in no way associated with the transmission at all. these autos are known to be junk, so the trans is just being itself.
__________________
1000RR
HID Kit Club #008 | DSLR Club #077 | G87P
FS: 98-00 OEM Sedan Tail Lights | shipping available
  #5
Old 08-09-2018, 04:28 PM
cumsies's Avatar
Junior Member
the thing is.. when the tranny started slipping, there was still a good amount of oil. with my 6ga, the car drops RPMs when never I come to a stop if I'm running low on oil. and that's an occurrence I deal with often. heck, we added oil when we took it to the shop just because and it didn't work.
maybe it is just ****ty auto transmission. I suspect it'll fuxx up again soon. so we'll see.
  #6
Old 08-09-2018, 05:06 PM
RedRyder's Avatar
RedRyder RedRyder is offline
Be a better driver
Points: 74,870, Level: 85 Points: 74,870, Level: 85 Points: 74,870, Level: 85
Activity: 51% Activity: 51% Activity: 51%
RedRyder has their shit togetherRedRyder has their shit togetherRedRyder has their shit togetherRedRyder has their shit togetherRedRyder has their shit togetherRedRyder has their shit together
Member Photo Albums
That's automagic.
__________________
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
» Featured Ride
