Go Back   6th Gen Accord DIY and Performance Forums > The Garage > Suspension, Brakes, Wheels, and Tires
Register to remove these ads
Reply
  #1
Old 10-14-2017, 04:14 PM
h22accordcoupe h22accordcoupe is offline
Junior Member
Points: 71, Level: 1 Points: 71, Level: 1 Points: 71, Level: 1
h22accordcoupe is an unknown quantity at this point
coilover recommendations for the street in 2017
Hello, I've been trying to figure out what coilovers to install on my 02 coupe, so I thought I'd join the forum and ask for some recommendations based on experience. I bought the car with function & form coilovers, and they are so stiff, the car feels like it doesn't even have a suspension. I bet if I crept the front wheels over a speed bump, and then accelerated hard I could get the rear of the car airborne over the bump. I want this car to be street driveable, that is just way too stiff. Not to mention living in the midwest, the previous owner did not wash the underside of the car adequately in the winter, so the road salt has corroded the coilovers to the point that they're no longer adjustable either.
Thanks for any help, or recommendations. I currently leaning toward the Tein GSH94-2USS2 street advance coilovers. (NOT the street advance Z version, which seems to be a cheaper version?) What are you guys rolling on?
  #2
Old 10-14-2017, 04:23 PM
NSWDoc's Avatar
NSWDoc NSWDoc is offline
Points: 3,696, Level: 17 Points: 3,696, Level: 17 Points: 3,696, Level: 17
Activity: 6% Activity: 6% Activity: 6%
NSWDoc is an unknown quantity at this point
Re: coilover recommendations for the street in 2017
Nope...Godspeed Mono SS...PERIOD.
  #3
Old 10-14-2017, 05:53 PM
Junior Member
12/8 kg/mm vs 7&4, those godspeeds have almost twice the spring rate of the teins I mentioned.
  #4
Old 10-14-2017, 06:21 PM
Sketch o5's Avatar
Sketch o5 Sketch o5 is offline
purp og
Points: 123,981, Level: 100 Points: 123,981, Level: 100 Points: 123,981, Level: 100
Activity: 99% Activity: 99% Activity: 99%
Sketch o5 is a name known to allSketch o5 is a name known to allSketch o5 is a name known to allSketch o5 is a name known to allSketch o5 is a name known to allSketch o5 is a name known to allSketch o5 is a name known to all
Member Photo Albums
tein is known for being softer, so they'll probably be your best bet as far as coilovers go.
__________________
1000RR
HID Kit Club #008 | DSLR Club #077 | G87P
FS: 98-00 OEM Sedan Tail Lights | shipping available
  #5
Old 10-14-2017, 06:33 PM
Junior Member
Yeah, that's kind of why I was or am leaning towards tein, and being made in japan sure doesn't hurt. I had ground controls & revalved bilsteins on my old vtec swapped accord hatch, but the people at ground control infuriated me, I swore I'd never buy anything from them again. They were a little stiffer than the oem setup on my 2011 VW Golf diesel, and that VW was about as stiff as I'll ever go again. Amazingly stiff from the factory. (45mpg though!) Definitely looking for a streetable setup here, the roads aren't that great where I live.
  #6
Old 10-14-2017, 06:59 PM
RedRyder's Avatar
RedRyder RedRyder is offline
Be a better driver
Points: 74,635, Level: 84 Points: 74,635, Level: 84 Points: 74,635, Level: 84
Activity: 51% Activity: 51% Activity: 51%
RedRyder has their shit togetherRedRyder has their shit togetherRedRyder has their shit togetherRedRyder has their shit togetherRedRyder has their shit togetherRedRyder has their shit together
Member Photo Albums
Teins sound like your ticket. I'm on Koni Yellows paired with Ground Control sleeves, 10.7k front/8k rear. Does everything equally well so I have been happy, and there is a lot of dampening/height adjustability.
__________________
  #7
Old 10-15-2017, 01:02 PM
NSWDoc's Avatar
Well that makes more sense then. I like being able to run autocross and circuit. LoL!
  #8
Old 10-29-2017, 02:32 PM
aeastman1204's Avatar
aeastman1204 aeastman1204 is offline
Junior Member
Points: 1,117, Level: 8 Points: 1,117, Level: 8 Points: 1,117, Level: 8
aeastman1204 is an unknown quantity at this point
Personally I would've suggested Function and Form, but seeing as you're trying to get away from them I would go with the Tiens. I've heard plenty of good things about them, and being made in Japan is nice too.
That being said, I'm looking at getting some Function and Forms for my 2000 V6 coupe but have been putting it off because of other expenses. If you want to let them go after replacing them feel free to shoot me a PM.
  #9
Old 11-01-2017, 09:16 PM
Eclipse99fwb Eclipse99fwb is offline
Senior Member
Points: 3,081, Level: 16 Points: 3,081, Level: 16 Points: 3,081, Level: 16
Eclipse99fwb is an unknown quantity at this point
My accord came dumped on ground control paired with tokico blues. First whatever you use do not use blues for struts they pretty much are oem spec and will not last. Im about to replace mine with illumina struts as i wont need a conversion to use yellows like i want. I will make a post after i install and ride it for awhile for a update. As for the coilovers they work great despite all four struts being blown, i would use them again as long as its paired to good strut. They handle good in the snow ive been through two winters with it and zero issues with traction. Hope this helps you out.
__________________
Anything made by one man can be overcome by another.
  #10
Old 04-27-2018, 02:28 AM
jypatric jypatric is offline
Junior Member
Points: 3,263, Level: 16 Points: 3,263, Level: 16 Points: 3,263, Level: 16
jypatric is an unknown quantity at this point
The Tein coilovers are not too stiff. They can improve ride quality.
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
» Featured Ride
