Go Back   6th Gen Accord DIY and Performance Forums > The Garage > Suspension, Brakes, Wheels, and Tires
Register to remove these ads
Reply
  #1
Old 04-18-2013, 03:42 PM
ESP.net ESP.net is offline
Points: 5,886, Level: 22 Points: 5,886, Level: 22 Points: 5,886, Level: 22
ESP.net is an unknown quantity at this point
ESP.net 98-02 Accord Traction Bar System with Front Torque Mount Kit F/H 4 cyl Models
Hey guys as you know we have quite a few products for the 90+ Accords from Mount Kits, Traction Bar Systems to Solid 2/3/4 Point Strut Bars/Tie Bars...
I am going to make the 98-02 Accord 4 cyl Models Traction Bar System with Front Torque Mount Kit F/H. I thought I would post this up with the whole process.
I am going to explain what we are thinking of doing. As you can see below is a 98-02 Accord 4 cylinder model. They have what they call a K member which most cars use now.
The issues... each side of the motor has a beam from front to back. This is un boltable. Honda have had these in the past on various vehicles for impact. Most cases are flimsy and we do not use in our kits. In order to use the 2 beams I would have to either lower or higher the radius rods in order for required wheel clearance....
The much easier solution is just to simply not use the boltable side beams on each side. The end result will look much like below.
I am currently in the process of making it and will post up more information shortly hoping to have it finished and into production in 2 weeks. -John
Please do not discuss how much, etc etc... this is just a process thread and discussion
Q: Why and what will this do?
Prevent wheel hop and torque steer. It will keep the nose of the car down under launching it will grab traction much quicker and go straight. Only way to fly to get from point A to point B as fast as you can. It will also strengthen the front of the car, improve overall handeling and road response. The Front Torque Mount Kit will put more power to the ground, improve shifts with eliminating unwanted engine movement. It will also give the necessary clearance for Turbo Downpipes and Custom Headers.
Production Picture:
Installed on Customers Car:
  #2
Old 04-18-2013, 03:46 PM
Re: ESP.net 98-02 Accord Traction Bar System with Front Torque Mount Kit F/H 4 cyl Mo
What the 98-02 Accord 4 cylinder Chassis Looks like below: Undo the spaces and copy paste.
http ://myimages.bravenet.com/347/171/808/1/98-02.jpg
What the final product will appear much like: Undo the spaces and copy paste.
http ://myimages.bravenet.com/347/171/808/1/TG.jpg
  #3
Old 04-18-2013, 04:11 PM
NASOHC's Avatar
NASOHC NASOHC is offline
Senior Member
Points: 15,615, Level: 37 Points: 15,615, Level: 37 Points: 15,615, Level: 37
NASOHC is more helpful than most
Member Photo Albums
Send a message via Yahoo to NASOHC
Interesting, subscribing to this thread... let's hear some feedback!
  #4
Old 04-18-2013, 04:18 PM
WHEEELMAN's Avatar
WHEEELMAN WHEEELMAN is offline
Senior Member
Points: 13,708, Level: 35 Points: 13,708, Level: 35 Points: 13,708, Level: 35
Activity: 6% Activity: 6% Activity: 6%
WHEEELMAN is more helpful than most
Member Photo Albums
Nice, thank you for going with this project man.
Possibility of working on V6 models too?
I think they use the same K-frame on 4 and 6 bangers --> i might be wrong but I do know that the Ultra Racing 4 point brace mounts to both 4 and 6 banger k-frames, so.... maybe your Traction Bar set up will end up working on both?
  #5
Old 04-18-2013, 04:33 PM
It is very possible, schematics show similar cross members. Part numbers are not the same for each. But that doesn't mean a lot. Could be something as small as a added bolt or a different front member for V6 front mount.
Wrecking Yards schematic show no inner change-ability. 4cyl and v6.
They appeared close when rumaging the local wrecking yard.
They do appear to bolt up the same... so possibility is there. Might just only have the make a different Front Mount Torque Mount Kit for the V6.
  #6
Old 04-18-2013, 06:08 PM
bdeitemeyer bdeitemeyer is offline
Senior Member
Points: 10,623, Level: 31 Points: 10,623, Level: 31 Points: 10,623, Level: 31
bdeitemeyer is somewhat reliable
Correct...K-frames are different from I4 to V6, although they have the same bolt points.
  #7
Old 04-19-2013, 02:18 AM
9450erick's Avatar
9450erick 9450erick is offline
Senior Member
Points: 11,813, Level: 32 Points: 11,813, Level: 32 Points: 11,813, Level: 32
9450erick is somewhat reliable
Member Photo Albums
ive been wanting to fab up one but my ideas no where near ur design. i was gonna run bars parallel to the radius rods. wanted to use the same design or close to what civics run. very interested
__________________
Ricer - you brought an accord?
Me-
Ricer- (10 sec later and counting)
Me - V-tec just kicked in yo:
  #8
Old 04-19-2013, 10:02 AM
jdm4eva jdm4eva is offline
Points: 3,371, Level: 16 Points: 3,371, Level: 16 Points: 3,371, Level: 16
jdm4eva is an unknown quantity at this point
definitely subscribed to this.
Can't wait for the final product.
__________________
TDK Photography
" It's not where your from, it's where your at "
www.nwp4life.com
  #9
Old 04-22-2013, 06:05 PM
1NonlyAccord's Avatar
1NonlyAccord 1NonlyAccord is offline
Senior Member
Points: 17,583, Level: 40 Points: 17,583, Level: 40 Points: 17,583, Level: 40
1NonlyAccord has their shit together1NonlyAccord has their shit together1NonlyAccord has their shit together
links didnt work for pics.
Im interested.I emailed a company to make custom traction bars for me.
following thread.
__________________
untuned turbo 217.01whp/238.46wtq @7psi
New setup-254.06whp/249.27wtq @10psi
RETUNED- 281.94whp/280.56wtq @11psi
Current tune-315whp/310wtq @14psi
  #10
Old 04-22-2013, 06:16 PM
akoutmos's Avatar
akoutmos akoutmos is offline
Senior Member
Points: 15,033, Level: 37 Points: 15,033, Level: 37 Points: 15,033, Level: 37
akoutmos has their shit togetherakoutmos has their shit togetherakoutmos has their shit togetherakoutmos has their shit togetherakoutmos has their shit together
Send a message via AIM to akoutmos
lol, i just moved to Seattle and was literally going to swing by your shop and talk to you about fabing something. I've been following your work for a while and you do some excellent work. If this does come together, you have a definite sale here.
__________________
???whp/???wtq @ 15psi (butt dyno says 260): Turbo Build / DIY Catchcan / Custom Downpipe / DIY Battery Relocate / Suspension Revamp / G23 Build
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
» Featured Ride
